What do i torque my manifold to on AFR heads???
juiced_94gt
1,143
Southern California
What do i torque down my Trickflow manifold on my aluminum AFR heads too?? and whats the patter to torque it down??? i cant find my Hayes repair manual and the shop told me to torque it down to like 15-18 ft. lbs. because of the soft aluminum...what is it for sure??? Do i use moly lube???
Be afraid :shock:
Be very afraid of soft aluminum threads anytime or anywhere :eek:
You want to use anti seize for two reasons :D
1) lubes the threads
2) dissimilar metals of Aluminum and Steel sets up a chemical reaction (white chalky corrosive powder) ... the anti seize helps keep that from happening
No more than 18#'s sounds about right :nice:
You will need to run the lower bolts over and over in sequence until they
take a final torque of that 18#'s.
After two heat cycles ... Run em all again ;)
Someone posted that sequence just a week or so ago :shrug:
Grady
Now AFR told me do not torque the intake down.. Just snug it down good. Take a very good chance on pulling the threads out.. But that was 3 years ago...
This info is included with the booklet you get with a new set of AFR heads
so what you speak of is good advice for sure.
I refrained from using the word ... Snug ............. Well because .........
My idea of snug is most likely not the same as your idea of snug ;)
Just for the heck of it ..............
After snugging up my Edelbrock lower
I found my torque wrench clicked at about 15#'s on my combo :D
The idea here is to get an even clamping force through out the entire
length of the manifold :nice:
I did mine in two steps of tightness with half in one set of sequences
and half in the final set.
After a couple of heat cycles you will find some will be loose :eek:
so it is a good idea to go over them one final time ;)
I do not use rtv or any kind of gasket sealer on my gaskets as
the gasket itself is for that
Yes ... a litle dab in the corners of places like intake and front cover
Anyway ... You'll end up with two main thoughts here
I don't wanna hose up my soft Aluminum threads :nono:
but yet
How tight is tight :shrug:
A torque wrench can put us all on the same basis of tightness.
Now ... The official Ford Service Manual calls for 23-25#'s
but ...
Oem conditions are such that you tighten bolts in threads of IRON heads
I can only share what has worked for me :shrug:
Grady
I use antiseize on intake bolts since they are going into aluminum for the couple reasons that final5-0 stated.
I use oil for engine lube, not bolt thread lube:)
