Help with AFR reading
dz01
285
10
Massachusetts
I recently install an ARF to help with carb tuning on my 68.
Background:
  • car overall runs good.
  • fires right up but struggles to idle without me feathering for a few mins (I have a manual choke 4100 just rebuilt by All American). Once I get high idle, works fine and idles fine when warm.
  • car seems flat to be anything over 3k rpms. That’s why I wanted to see what carb is doing with the ARF.
The digital AFR bounces around quite a bit but here’s what I think I have.
Idle- between 13.7-14.4.
WOT- hard to tell but I’d say I’m in the 12’s but will jump to 14’s pretty fast
deceleration (foot off gas in 4th)- 14-14.4
I’m really never higher than mid 14’s.
not that I care about fuel mileage but I am getting 7 mpgs. If my 289 was pushing 400hp I wouldn’t care but for a few mod motor (cam, .30 over, headers) I would expect to get 15 or more. I am playing the timing game where at 10 I was getting hard starts when hot so bumped to 12 with 38 total. No pinging and seems to run fine other than lack of balls over 3k. I’m not as seasoned as most of you are so still learning. Fuel mpgs and seat torque just seems off to me
It's idling a little rich.
12s at WOT is throttle is good. It [should] lean out [immediately] when you take your foot off the gas.
This is fine. Might be a little fat but it's within the margin of error. If you lean it out at idle this will change too.
Alluded to this already but somebody that knows carb jets better than me might be better at advising how to best adjust.
Reactions: dz01
2 questions about your idle: what is your idle vacuum and have you tuned the idle circuits to obtain the most vacuum that you're able to get?
1 suggestion about WOT - it seems like your discharge nozzles may either be too big or the pump timing needs adjusting. Also, I don't know much about the 4100, but you could try bumping the jets up a couple sizes to maintain a lower AF reading while the throttle is still wide open. Otherwise your ratios don't sound too horrible. What are they at part throttle cruising? The rough guidelines I went by when I was messing with my Holley were:
Cruise - I shot for something close to 13.5-14.0
WOT - somewhere around 12.5
Idle was wherever it ended up, but it was usually a little lean - somewhere between 14.7-15.x iirc. But as was pointed out to me, idle is set to the highest vacuum you can get out of the engine.
You'll have to keep in mind that those numbers are going to vary no matter what you do, especially when the weather differs wildly from day to day. I never did completely finish tuning my Holley before I bit the bullet and got myself a throttle body injection setup, but you can reference my thread on tuning the Holley with the AF gauge, maybe it will help you some.
My vac at idle is around 12. I have an unknown cam so I’m not going to pull 18-20.
I think cruising in at around 13
