Hello everyone! I am a newbie here, but i have always loved the mustang. i have a 95 GT, working on posting and editing my profile. anyways, my mustang consist of holley heads and cam, ford 1.6 rockers, bbk heads, borla mufflers, summit radiator(1yr), new water pump (3wks), alum drive shaft, 3.55 gears, custom chip and 5sp ( with second gear issues). My problem is that the temp in El Paso ("The Sun City"), TX. is getting pretty close to 100* and my car will over heat if i turn on the AC.
the radiator fan will come on. i have had this issue for several years now and every year i try something new like the radiator and water pump, since income is low (i am a student). I'm pretty much fed it with is and i wnat to resolve the issue once and for all.
I read a post and saw this by hissin50,
If a car runs hot at speed:
Ensure the coil is not clogged with debris.
Ensure the air dam is present under the car.
If the above is true and the car becomes even hotter and struggles to cool down with the A/C being on, that can suggest the coil is simply unable to reject enough heat. A new radiator is often the best move from a monetary standpoint (as this allows an upgrade at the same time. Nice for hotter climates or modified engines).
I have serveral questions to this.
1) what coil is hissin50 talking about?
2) where is it located/ any pics?
3) what does the air dam look like?
adnd of course, does anyone have what is wrong with my car or any suggestions?
thanks you guys.
I read a post and saw this by hissin50, If a car runs hot at speed:
thanks you guys.
Sorry guys. the stock ( i know it is carppy at best ) will read A in NORMAL, but i am pretty sure is will go past L is the cur is not turned off. Working on getting an autometer gauge. but if the AC is not turned on the gauge will read R and will go back to O. When the dyno tune was done, the lower speed fan was to turn on at 120* and the high speed fan at 150*. And again High speed will kick in as soon as AC is turn on to high.
