I have decided to go to a full manual valve body. That will definately get me on the road. And it should make you manual guys happy because I'll still be shifting manually, just without having to use my left foot.
It is what they call a "forward pattern" valve body, which means that it goes "P-R-N-3-2-1" with a switch for OD and another switch to lock up the torque converter.
So this ratcheting B&M shifter has got to go. Why? Because in order to go from Park into 1st gear, I wil need to pull the shifter 5 times, letting it go back to the middle after each pull. I am sure that will quickly get old.
What I would realiy like is a shifter with a "T" lever I can squeeze to unlock the gate, so that I can go from Park to 1st in one easy motion. I looked at the Hurst Quarter Shifter, and it looked pretty cool, but the handle moves really far from Park to 1st, and I'm not sure there is enough room.
So I need you guys to school me on shifters and sell me on which one I should get. For now, I'll use the B&M, but I fully expect to be wanting to change the shifter before long. Hopefully there is one with 2 switches that I can use for the OD and TC lockup. Or maybe I could put the switches on the steering wheel near the cruise control or something.
