What oil for a T-5?
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
I am going to change me tranny fluid. I am pretty sure a non-WC T-5 uses ATF, but Ive had some people tell me that they have ruined a T-5 with ATF.
EDIT: And how much?
I am one of the few that runs Syncromesh in mine. I like it. No problems yet.
I "think" that Mercon / Dextron ATF is the rcommendation on it, though. Don't hold me to it. I'll let some one else chime in on it ....
Ok I got some Castrol ATF (Meets DEXRON III and MERCON requirements).
That will work right?
And none of the parts stores around here have hand pumps for the oil. They are useless I tell you. :notnice:
If you have a little RTV at home you could drain the tranny from the drain plug...and just take off your shifter from the tranny and pour the fluid in thru there. Then use the rtv apround your shifter when you reinstall it. Yea its 4 bolts instead of a fill plug but its much easier if you ask me.
I actually might do that.
I hate getting under my car. Its so low.
Yea they havent used NWC T5's for a while now. I learned that during my re-build. Use ATF as previously stated. I used ATF-4, Well because its free at work:D And i feel its much better to do it from the shifter but you should have someome look under the car and be ready to put the fill plug back in once they see the tranny fluid start to spill out of the fill hole. I love these T-5's they are so easy to work on :D
Why would you need to have the fill hole open if you are filling from the shifter?
Also if you dont have another person there just make sure your have some sort of silence and a drain bucket under there and just fill till you hear it spill and try and get under there quickly to put the fill plug back in.
