Need help troubleshooting A/C Issue
Lyonmt
110
Tampa, FL
I just bought an '88 LX 5.0 for a commuter/beater. The a/c doesn't work. Here's what I've done so far.
Jumped the switch at the condensor - The clutch did not engage.
Jumped the compressor - it goes out and clicks.
Checked the fuse - it's good
Checked the pressure - 100psi+
What's next? I think there is a relay under the hood on the driver's side, no?
Check the WOT (Wide Open Throttle) relay located on the fornt of the passenger side strut tower. The relay and wiring often have heat damage.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
Ignition switch wiring
Fuel pump, alternator, ignition & A/C wiring
Computer, actuator & sensor wiring
Fuse panel layout
Vacuum routing
I think I found the WOT relay. It was located on the passenger side for some reason? The wires going to it have lost a lot of their insulation and are probably shorting out. I imagine that they may have shorted the ECU. Ugh!
The WOT relay is on the passenger fender as you noted. The vulcanized insulation is common.
When the AC is on, the current to the clutch passes through the WOT relay's common and Normally closed terminals. When WOT is achieved and the computer desires to shut off the compressor, it sends a ground pulse to the coil, which energizes the relay and opens the circuit.
If you do testing on the relay, use a meter and not a test light (the light can ground the relay).
Often, just moving the relay around (after insulating the wires) in your hand will make the AC come to life.
Replacing the relay is no biggie.
Good luck.
Good luck.
I found this diagram, http://www.veryuseful.com/mustang/tech/engine/images/88-91_5.0_EEC_Wiring_Diagram.gif
So my next steps are as follows, verify that I am on the correct path please:
1. Test for voltage at the relay. Using the diagram posted as a guide, it seems that I should have voltage at the pink/light blue wire going into the relay. Especially if I jumper the pressure switch. Correct?
2. setup a temporary, but solid ground to the compressor.
I think the voltage test at the relay will really give me some useful information. I'll try this when I get home and keep you posted.
As long as I follow the flow of voltage in that diagram, I shouldn't have any problems finding the issue.
If I am not getting voltage to the switch, then I guess the next thing I need to look at is labeled "A/C Dem switch" which I suppose is the 'A/C Demister' switch on the dash?
When you turn on the AC, if the system has enough refrigerant, the LPCS will close and send 12 volts to the WOT relay's common terminal. This is the pink/lt blue wire you noted. When you have 12 volts in this wire at the WOT relay, the blk/yellow wire should also have 12 volts [while at idle]. If so, look for 12 volts at the AC clutch connector. If you have it, ohm out the clutch's ground.
If you are missing 12 volts into the WOT relay, check the LPCS for I/O voltage.
If you have 12 volts into the WOT relay but not leaving, ensure the orange/lt blue wire does not show continuity to ground. If it does, the clutch wont engage. Period.
FWIW, I think the diagram JRichker posted is easier to read. Yours is good if needing pin numbers.
Good luck.
If you only have 0.20 volts leaving the HVAC controls (and going into the LPCS - your first picture in post 8), check the wiring at the HVAC unit. Once you have 12 volts restored to the circuit, it should come to life. I'd check I/O voltage at the HVAC controls.
BTW, nice diagram editing. I'm jealous of folks like you and Jrichker whom can do that. :nice:
Good luck.
Good luck.
Too late to work on it tonight. I'll get on it when I get home from work tomorrow. Thank you for all of your help, I'll keep you posted.
P.S. Thanks for the BTW.
So I remove the HVAC control to test for voltage. It has 12 volts going in. So I plug it back in and low and behold I have 12 volts going out. Great, must be a bad wire. OK. So for giggles, I go and test the pressure switch, but as I am wiggling it apart I catch the compressor click out of the corner of my eye. I plug it back in and the compressor kicks on!
Okay, so I am thinking it has some oxidation and needs to be cleaned. Awesome, I'll do that tomorrow when it's not raining. I then get back in the car and find the cool (not cold) air blowing out of the defroster vents. Huh?! So I take a look at the vacuum lines on the back of the HVAC unit and seems that there are supposed to be four lines (I hope) and they are not kinked or leaking as far as I can tell. However my not-so-cold A/C blows through the defroster vents. Sigh. Hopefully it will be nice tomorrow night and I can diagnose it further. At least I have something for the hot/sticky commute home tomorrow!
Nice work.
On the vac situation (the HVAC not receiving a proper vacuum signal is indicated by the default 'out the defroster' symptom), check all your lines again. Note the main feed line (it's yellow as I recall, and goes to a cannister) - it might have come unplugged.
Edit: Here's a picture, courtesy of Tom Moss:
attachment.php
Also check the line at the vac tree. There's a dedicated AC port IIRC (I get the fox and SN95 stuff confused sometimes but I think I got this right).
Good luck.
Nice work.
attachment.php
Good luck.
You da man! Thanks again!! :flag:
The vacuum line under the driver side dash was disconnected (just like the picture you posted, Thanks again!), I connected it and now the vents blow barely cool air. I think I'll evacuate the system and refill with R12 from eBay. Easy Peasy (and cheap!).
Thank you all for the help. I LOVE this board!
What does it mean when I have fittings that look like this ( I bet it means the car was already converted to R134A (or at least they tried)):
Those are R134 conversion fittings if they look like these...
When a R134 conversion is done, the installer is supposed to replace the service fittings with R134 style quick connector couplings.
Typical low pressure side R134 coupling
Typical high pressure side R134 coupling
That's what I figured. I don't know why it didn't click before, but I guess I'll have to find an adapter now. I have a vacuum with the R134A threaded fitting, so hopefully the auto parts store or Harbor freight has an adaptor. I also, already have a can of R134A, so once I find that adapter, I'll drain the system and refill. THe system has pressure and the clutch works, so hopefully this is all it needs. Otherwise, I am gonna quit the fight and bring it to Midas. :(
