San man, I respectfully disagree with you on this one, I'm not looking for a flame war, just a conversation.
IMO, the problem with the rears in the GTs is that Ford used the control arms to do 2 jobs, one was to locate the rear under the car, and the other was to locate it side to side, this is, I believe, the reason for the upperarms to be at an angle. What happens is that during up and down movement the upper arms must bind to continue locating the rear. This is manifested in the handling by the car going into a "snap" oversteer, usually on corner exit. The problem seems to get worse when the car is lowered, because the rearend seems to be in this bind mode all the time. Without a doubt, the lower arms are a good investment, the Panhard Bar is a great move, but the job is not over until you address the upper arms. Providing that you can't saw the stock locations out of the car and relocate them parrallel to each other, the next choice would be to fabricate arms that would use a heim joint to allow for movement. (I'm not sure this would even free it up completely) and let the Panhardbar locate the rear side/side. A lot of fabricators sell upper arms but not too many have the arms that are heim jointed, you'd probably need to see MM, Griggs, or some other hard-core race fabricator to find these.
San man, I appreciate your opinions, they're generally dead on and I respect your work on these pages, I just feel that in this case there's more to it.
