you forgot the six pack abs! I still weigh less than your 192.
Actually Im 200.5, a previous weighing on the track scale said 2704, I just used the lower number from the second time
So Travis is there a guard on the PS3 to filter out adult content so it can't be viewed on the web or downloaded to the PS3?
**** in HDOn another note my car keeps going lean shortly after stepping on the gas. It goes rich for a second then starts climbing quickly to 15 or 16 AF ratio. ANy ideas what tables I could start messing with, Chris?
Did you put the fuel pressuer to 40 psi? You'll need to do that first. After that, then the MAF curve could be changed a little. There is another fuel enrichment setting. I can't think of it right now...
It probably still low quality movies just upconverted to HD. It just seems awefully expensive to make a true HD **** movie. Not like you can do it with a regular camera. I don't know if I want to see that bad acting in HD.**** in HD
^^^ dude you need to find another store man
when I put the PMAS in I made sure it was set to 40. Recently I gave the regulator a extra 1/4 turn to up the pressure and try to get rid of the lean condition.
It will go rich but only for a second before the computer corrects and puts it back to lean, even at WOT. I was just wondering if I need to mess with the load tables. Even with the tweecer off it still runs lean which seems weird to me.
**** it!!...just spray that bitch!
Give it hell doggy!!!!!!
She'll go or she'll blow. There is no in between.
I'll hook up the 20lb propane tank!
