Problems encountered while attempting to break-in a new cam
jeffnoel
1,638
Clovis, CA
I tried starting the Mustang after the winter mods and it won't start. I have gas, 5 gallons added to the recently cleaned and sealed gas tank. Fuel filers are clean and I have spark, I checked by pulling the #1 plug and grounding it to verify spark at the plug. I prefilled the fuel bowls in the Holley carb by pouring gas into the bowl vents. My problem I think is I have a bad fuel pump. I have a gauge at the carb and it never shows any pressure building when cranking. I pulled the line from the pump to the carb and it was dry, so I'm thinking the pump isn't working.
Any ideas, I did prelube the engine with a drill and got 50 psi at the gauge. But, I'm afraid if I keep cranking it and it doesn't start I'm gonna ruin the new cam.
Thanks for any suggestions or help.
If you have the floats filled, it should fire then quit once the floats run dry. Try spraying a little starting fluid and see if it fires then quits. Otherwise, your distributor might be 180 degrees out or out of timing. Something to consider
You've likely got the timing too far off to get it to fire up. Line up the timing pointer to the marks on the balancer, then loosen the distributor hold down clamp. With the key on, and the #1 plug pulled and grounded (like you did before) slowly rotate the distributor back and forth and watch for the spark. When it sparks, the timing will be dead on where you have the pointer lined up to the balancer mark. It should start immediately after you replace the #1 plug and try again. Set the timing to about 10* BTDC to start and run in the cam with. Also make sure the idle speed screw is set far enough to allow the engine to run cold till it warms.
That's kinda what I'm thinking. Even though I'm pretty sure I've got a bad pump (new Holley 80 GPH pump should be here tomorrow) I thought it would have fired since the fuel bowls were filled and even a little gas shot into the throttle bores as a last ditch attempt.
Thanks for the timing tip D.Hearne. I have an MSD 6A ignition box that was working before I swapped cams will trying to time the motor like you describe have any ill effects on my MSD box?
Any others???
So I checked a couple things out. I removed the valve covers and rotated the engine by hand and verified the standard 15426378 firing order and set the timing at 10 degrees on the balancer with the magnetic pickup lined up firing on #1. I also checked my MSD box and coil using the instructions I found on the MSD website. With the ignition OFF I pulled the coil wire from the distributor and placed it about 1/2 inch from the block (ground), then turned the ignition ON but no cranking I used a jumper wire between the green and violet wires at the connector on the MSD box which causes the coil to fire and spark jump the 1/2-in gap at the coil wire. I did get spark so it appears my coil and MSD box are working properly. My new fuel pump is supposed to come in later today, probably hold off on trying to start it again until tomorrow.
Timing set at 10 degrees
Distributor set to fire on #1
New Pump installed
Finally some good news, I got it started today but could only let it run for about 5-6 minutes at 2000-2500 rpm because it started overheating. I had the cap off the radiator to verify flow and before we got it on I lost about 1/2 of the coolant and the temp went to about 210-220 and I shut it down. It also appears I can't go by the timing marks on the Professional Products balancer either as I had it set at 10 degrees as shown in the picture but to get it started we started rotating the distributor until it fired and we checked it after I shut it down and the pointer is about 3/4 inch to the left of the zero mark on the balancer and the distributor pointing way right of center. So I think when all is done I'll mark and pull the ditributor and rotate it to the next tooth on the cam to bring vacuum can on the distributor back towards the engine centerline.
After letting it cool down I fired it back up it ran for about 1 minute before the alternator belt snapped and I had to shut it down again. By then it was 6:30 pm and I figured if I went and got a new belt the neighbors would linch me because the open headers at 2000+ rpm is loud as you know what. So I'll get a new belt in the morning and try again late morning while most are at work.
So have I done any damage only letting it run a few minutes at a time? I did see 50 psi oil pressure and have 2 gallons of Rotella and 2 bottles of Crane breakin lube in the pan.
Let me know your thoughts.
Thanks -Jeff
Here are pics of what I'm describing above.
Shutting it down and starting up the motor again later and immediately going to 2000-2500 rpm will not hurt the cam during break in. Letting the motor sit at idle during that time will be much more harmful.
Fill the radiator. Keep a garden hose handy and dose the radiator if the car starts to get hot. Might mar that pretty paint but it will help to keep the motor cool during the cam break-in.
Good Luck!
She's alive!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
<div align="center">
<object type="application/x-shockwave-flash" data="http://feat.putfile.com/flow/putfile.swf?videoFile=New-cam-broken-in" height="349" width="420" align="middle">
<param name="movie" value="http://feat.putfile.com/flow/putfile.swf?videoFile=New-cam-broken-in" />
<param name="quality" value="high" />
<embed src="http://feat.putfile.com/flow/putfile.swf?videoFile=New-cam-broken-in" height="349" width="420"></embed>
</object><br><a href="http://www.putfile.com">Upload Video</a> - <a href="http://www.putfile.com/weekvideos">Top 50</a> - <a href="http://media.putfile.com/code.php?n=New-cam-broken-in">Get Video Code</a></div>
If you have Felpro head gaskets, they don't need to be retorqued. You can check everything else, do them cold. Header gaskets need this about once a month for a few months before they'll settle. Maybe once a year or as needed afterward.
