Air bag light
squeak93
2,352
418
164
Joplin, Missouri
Anyone ever have the air bag light flash randomly? It has no patern to it that I can find. There is an airbag in the car as I had to remove it to replace a horn button. If the car is under hard acceleration it won't flash as often or sometimes not at all but when at steady throttle or idle it will flash. No specific amount of times to flash, sometimes 3 others 5 or 9 or 4.
Anyone???
BTW 92 gt auto. Completely stock except for o/r x and weld in mufflers.
Squeak,
I share your pain on this one. This 92 project car of mine also has a flashing airbag light. I haven't found a way to get rid of it. When we got the car the airbag chamber was empty..obviously had been deployed during a wreck. During the rebuild they just shoved the empty chamber back together. Cheap bastar%$#s. I bought a takeoff airbag from MPS, but the light still blinks.
I'm still searching for a cure...........Good luck,
Ken
I know mine would flash randomly like that. It went on for a while. Sometimes i'd be ok and other times it's a was constantly there. Turned out to be the airbag sensor in the front of the car. I could see that it was all rusted up and probably not functionning.
It should be flashing a code. Check next time (not while you are moving of course). For example, it may flash 5 times, pause, 3 times, pause, then 2 times and begin again. All the codes mean different problems with the airbag system. When the light bulb breaks, it will be replaced with a beeping sound that will make you wish the light still worked.
mine does this at times too. Infact its doing it now. Its the ground screws for the sensors. SOmehow they lose ground. I remove them sand around the holes and clean up the bolts. Tighten them up and the flashing light goes away for a year or two/
Sounds like what BlueBomber said. I will have to get in there and find the sensor. I am assuming its on the front bumper... What does it look like??? (hate searching for chit when I don't know what I'm looking for)
(Just recently got back into foxes from new edge's so I'm having to remember where and what everything looks like)
When you're standing in front of your car with the hood open, the sensor is the little box on the bracket attached to the front of the radiator core support just right of center.
I checked my airbag light today and it only flashes a "41". Does anyone have a book that lists the airbag codes? I would like to start chasing down the airbag problem, either figure out it's too broken to fix, or replace a good part and be done with it.
Thanks guys,
Ken
Wow, thanks guys. At least I have a direction to start looking in.
I'm showing my age and loss of memory here, but could you refresh me on how/where to get to this diagnostic monitor check? I have probably been over it a hundred times before I abruptly threw my 93 vert away, but I'm trying to recall all this data again...my head hurts?! It is nostalgic though!
Thanks for the help everyone,
Ken
Go to www.google.com and download the Google tool bar. Learn how to use the search feature and you too could look this up in less than 10 seconds.
53 | Diagnostic monitor internal fault
Looks like you've got a bad air bag control unit.
Ken
Your Diagnostic Monitor is located in the Dash behind the Climate Control Panel, its a Blue Box, you cant miss it. BTW since you have a 93 if your Monitor is bad you can only get one from a 92 0r 93.
Google really??? Would of never thought of looking there....:rolleyes:
I was really looking more for help and anyone else's past experience's. Thanks for sarcasm though. Always helps.
Shakerhood,
Thanks so much for the quick reply. Yes, now I recall that blue box. I have not looked for it on this 92 I'm working on but remember working around it on my 93.
You mention using the cables from the box to run the diagnostics. Is there a special reader that is used for this? I only have the standard code reader for computer codes and have never worked on the blue box. Is this something I can do or do I need to visit the friendly, expensive folks at my local Ford dealer?
Thanks again for all the help.
Ken
Well the Code itself comes from the Light in your Instrument Cluster, once you have the Code you need only a VOM to run Diagnostic Tests to pinpoint the Problem. Actually reading in my Ford Service Manual it says if you are Flashing a Code 53 then your Diagnostic Monitor is bad and you do not even have to run any Tests, thats a Plus! Remember you will need to use a replacement from a 92 or 93 Only, I changed mine this past Spring in my 92 and its a bit tough to reach in there but its not that bad!
Can these be bought new or they only avail used?? Used isn't a big deal as I have Mo Mustang close but just want to know. (Are we still refering to the blue box as what is bad with a code 53??) I have 0 experience with air bag problems. Just know they go boom when u hit something hard!!:D
I dont think they are available New, there may be some places that sale Remanufactured Units, I think I paid about 40 bucks for a used one. And BTW yes it is the Blue Diagnostic Monitor behind the Climate Controls in the Dash.
