What is this and how do I fix it?
zZsKyZz
503
I put on an RPM intake yesterday on my car, and everything is bolted up except I can't get the piece by the throttle body to go on. I don't know what it's called. It's kinda round, goes onto 2 Carb studs and has a pipe coming from it going down to the passenger side exhaust header. I can't seem to get it to fit onto the TB adapter, I've cursed, made up words you've never even heard before, and I still can't get it..
:bang: What is this stupid thing and how the hell do I get it on?! :bang:
Undo the tube from the EGR and loosen it from the header. Install EGR valve then try to snug it up. If not, you'll have to get creative and lengthen the tube. Seal it up though, or else the car is gonna have exhaust leaks and sound like a lawn mower...
Awww....Snap!
Uhh... I think I broke it.. Is there a way I can kinda just do without it? :bang:
It's a V8... we don;t need no stinking mileage...
You are right though... I took mine off completely and then tricked the compouter into thinking it is stuck partway. It puts so much timing in down low that I have to run premeium gas... When I get a twEECer this is one of the first changes I am going to make (turn this off). My EGR was never gettign a vacuum signal so it was never opening, then when I broke the pipe, case closed... :-)
50resto has new ones IIRC thats where I got mine that thing ain't cheap its 50 some bucks for that stupid pipe. You can cap it as others have said BUT if you have emissions you need it connected. They also make adapters to make it longer if need be.
