Vert top
hungrymonkey
White by Birth, Trash By Choice
12
108
Oregon.
89 Gt Vert, all stock.
The top is getting harder and harder to close. It is also not completely going down when the top is lowered. I think I nearly herniated myself when I closed it tonight. I literally had to lay across the passenger side support and manipulate the hook into catching.
I figured I would start looking at the cheapest possible problem. I was thinking it was the fluid level being low. So I did a few searches and found that a majority of threads regarding the fluid levels said to put type F atf fluid in the resevior. I pulled the rubber plug and found the current fluid to be clear. It also smelled like mineral oil?
so, in short. What type of fluid for my car? do I fill when the top is up or down? Is there any other common problems with these years of convertibles?
Give the dealer a call. Some form of hydraulic fluid obviously. I saw an aftermarket unit calling for "grey hydraulic fluid only". Mustangs Inc?
I'm surprised it didn't say on the pump housing. Mine does specifically call for red type F which I could see in the opac lines but it's an 84 sorry.
When my fluid level was low (due to replacing broken lines) it operated slowly is all - took along time to build pressure up before moving - especially back up. Had no effect on seating up or down. I just filled it with the top up and it was fine after that.
See if something is binding in the cables or mechanisms somewhere.
