89 Gt Vert, all stock.
The top is getting harder and harder to close. It is also not completely going down when the top is lowered. I think I nearly herniated myself when I closed it tonight. I literally had to lay across the passenger side support and manipulate the hook into catching.
I figured I would start looking at the cheapest possible problem. I was thinking it was the fluid level being low. So I did a few searches and found that a majority of threads regarding the fluid levels said to put type F atf fluid in the resevior. I pulled the rubber plug and found the current fluid to be clear. It also smelled like mineral oil?
so, in short. What type of fluid for my car? do I fill when the top is up or down? Is there any other common problems with these years of convertibles?
