So I was driving home...
Therian
The Highlander
Waterloo, Ontario
and I noticed my temp gauge was going up, fast.
luckily I only had about 500 yards until my place. I parked it, promptly shut off the engine and opened the hood. It took a bit of time, but coolant started flowing steadily out of the overflow bottle and onto the road. I could also hear hissing from the valve covers, and see coolant bubbling out between the gasket and the VC.
I had a tstat done about 3 years ago when a similar problem happened. Could it be stuck open? Where do I go from here.
Looks like this is the last straw and I'll be putting her away until next spring when I decide what to do next.
i've never heard of coolant comming out of the valve cover....unless you have a coolant oil mix running through everything and comming out of your valve cover...but that would be bad
I'd check compression or do a coolant system pressure test.
If you have a blown headgasket it could be pressurizing the coolant system (resulting in coolant overflowing) and causing you to overheat because the radiator just can't dissipate the heat from the combustion gas.
if the coolant really is flowing from the valvecover....then I'd have to put my money on a blown headgasket.
btw, a car can still run well with a blown headgasket....so just because the car runs well isn't a clear indicator that a headgasket isn't the problem
good luck
+1 on the coolant pressure test....cheapest and easiest way to go if coolant is comming out anywhere, you will find the leak more than likely....if you dont have a pressure tester, you should be able to talk someone at a shop into pressure testing your car for free (takes all of 30 seconds and no tools)
This sounds to me like you're getting overpressurization of the coolant inside the engine itself, and there can only be two reasons for that:
Thermostat sticking closed
Blown head gasket (cracked head less likely but possible)
The thermostat obviously did open eventually because the coolant started flowing out of the overflow reservoir. The simplest thing to do would be to replace the thermostat. Test the new one first in a pan of boiling water before you install it because even new ones can be faulty (I had a new Motorcraft 192* thermostat that wouldn't open so that's how I know). I went for a Mr. Gasket 180 degree unit.
