bbk 4.6 intake manifold
I saved this when I came across it, I can't remember where from ATM (apologies to whomever took it).
Sure doesn't look like a cheap intake to me, and much like the P51 it doesn't look like it uses stock fuel rails.
o.0 I like the look but only time will tell if it will be worth a damn. But it sure does look spendy.
but with individual throttle valve, its gonna need ECU tune too won't you think?
stock rail prolly not gonna work either.
But this one may actually produce some power(more then few like others).
And being cast aluminum, I can prolly polish the hell out of it too...
apparently the intake is designed so you dont suffer low end loss,its supposed to make gains across the board but like everyone else says we shall see.im not a fan of bbk myself but from all the designs im gunna hold out on the release of this one.supposed to work similiar to a cobra design with the imrc plates.
This made think that thats not an idividual throttle body.
I wonder if it could be more like old variable intake like an old toyota TVIS they used to have in their mighty 4A-GE in the pre days of VTEC...
My old MR2 had it, and it grately helped low end torque by manipulating intake charge volume and speed...
http://www.gtfours.co.uk/what/tvis/tvis.htm
I called BBK on this the other day! All the person I spoke with could say was it is still in testing and probably wont go into production till late summer 2008! It was also said an upgraded fuel rail system would most likely be an option with it!
