its only there when the clutch pedal is not pressed. when i press the pedal in the noise goes away.
A grinding type sound when the clutch is pushed in is a symptom of the TOB also...
^ The grinding noise I'm talking about when depressing the clutch (TOB is bad) sounds more like a whiney power steering pump type sound than a click/crunch. Yours sounds like maybe the clutch should be adjusted or something? Is the sound coming from the transmission area or from the pedal area?
Pilot bearing/bushing?
Your issue in the other thread is something mysterious.![]()
that click/crunch noise came back
so i just came back from breakfast. i took the car over so i could reset the clutch. it seemed to have worked until i was coming back and i pushed the clutch in around the last turn into the parking lotthat click/crunch noise came back
regardless of that though my clutch pedal feels excellent now. i should have reset it a long time ago.
however i was hoping that it was partially reset, giving me this strange noise :-\ o well
Try it again ... isn't gonna hurt. When you have time, check the cable and make sure it's not frayed or anything. Something on that little gear (adjuster part) could be what is clicking ... probably is actually. Lay down all crazy style with your head under the dash and look up by the clutch to see if anything seems out of wack.
