Wheel Hop..grr.
I'd like to see a pic of the bars installed. If you bars hang too low, when the axle wraps, the bars won't hit anything. If they don't hit anything, they can't prevent leaf wrap, or wheel hop.
Pinion angle is something to look at. But does it vibrate on accel or deccel ?
,,,,,,,,,,,,. Installed some Rancho 9 way adjustable rear shocks and put spring claps on the front half of each spring, 3 per side. Clamps are cheap and easy to install. This combo completely cured any wheelhop. I can launch as hard as i want now and not hint of hopping...:nice:
Questions:
Do the clamps allow any slip at all between the leaves?
So do you run this way on the street too?
Or do you only have the clamps on for the track?
Questions:
I run the clamps all the time street and track. Not sure when you mean by "slip". The clamps keep the each individual leaf from seperating under hard acceleration which can lead to axle wrap/wheelhop. The back half of the leaves do seperate as I don't have clamps there.
The individual leaves slip on eachother allowing the shape of the arc to change and act as a spring.
I was wondering if the front portion was still doing this with the clamps in place, or if it is now acting more like a solid link (like a ladder bar)?
Yup, now I'm the never ending quest to fit big tires. Rear end narrowing is on the way, any other ideas? Would it be possible to squeeze a 13" wide tire in somehow?
And I was thinking today, lets say I got a fuel cell right, I could remove the rear deck temporarily, mini tub the wells, and weld it back on? How much frame work would be involved?
Thanks for all your help guys, I have to much thinking I just need to drive. ahh.
