its really simple. they charge way too much money for what they actually do IMO.
all you need are 4 speakers and some speaker wire. i run these speakers and i have never distorted them. thats $100 plus shipping.
http://www.millionbuy.com/piotsa6871r.html
first unhook the negative battery cable and pull the radio out
running the speaker wires requires removing some interior panels, sn-95's have a pretty easy interior to take apart.
both trim pieces along the bottom of the door jam need to come off. they're held in by clips so pull straight up from the front to the back, at the end closest to the backseat there are tabs that keep it straight, be careful not to bend these.
take out both kick panels after trim is up. (the trim helps hold it in place)
remove bottom of the back seat
remove the top of the rear deck cover via two bolts holding on the top of the backrest.
next remove the rear deck cover itself by kinda folding/working it out.
now drop the 460 amp rack by the bolts now exposed on the rear deck.
disconnect all wires and tuck them in behind the trunk liner for future possible use
now your door panels need to come off. take out the door cups by prying at the top with a flat head again being careful not to break any clips. there will be two screws under it that need to come out. the last fastener is in the front of the door, its a plastic push pin type deal (like on the kick panel)
now just lift up on the door panel more or less to remove it.
now its time to run your wires. i would run the back wires along the passenger side. the door wires need to be ran through the rubber gromet accessible by the kick panel.
you might need to download a radio manual to identify wire colors.
reassemble in the reverse order. and save $500
