Ok well I found a carbon fiber DS for autos made by PST (precision shaft technologies).
PST-1200S 1996-2004 2V Mustang "Street" Driveshaft-Auto $609.99
Carbon Fiber Driveshaft Specs.:
Lighter than steel or aluminum.
Three times the torsional strength of steel.
Torsional spring rate allows better tire hook-up.
Torsional spring rate allows smoother shifting.
Less shock load to the differential.
Eliminates or dampens high speed vibrations.
Reduces transmission and differential breakage.
Supplied with Steel Yokes.
Better 60 ft. times in drag racing applications.
ET's have been lowered in some cases by as much as .120.
In road racing smoother shifting and better durability of transmission and differential have been reported.
Tested on Cobra's at 180 MPH on Dyno with no vibrations.
A much greater safety factor, carbon fiber will return to a fiber and not create shrapnel under the car, as would aluminum or steel shafts.
"Street" Carbon Fiber Driveshafts are good to approximately 500-600 rear wheel horsepower and feature 1330 joints. They can be used with a factory style pinion flange.
