I want blinkers PLEASE HELP
Kdubslugga
1,515
Akron, OH
2 years ago I did a t5 swap and havent had blinkers since. Ive replaced hazard switch twice, multifunction switch twice, had the whole dash apart speedo cluster and all to see if any wires where broke nothing. I checked for power to the hazard switch check power to multi swicth both have power, im totally lost at what to do. hazard work great no blinker. Tell me something, im furious as i write this
have you checked the fuse to make sure it wasnt blown? I didnt see that in the list of things you checked.It's fuse 5
Are there by chance, any other sypmtoms that go along with your blinker dilemma? Are other "funny" things happening elctrically or is it only the blinkers that are INOP?
no, the module should be a seperate flasher that is located away from the multi function switch. look behind the radio or the glove box for a blue bulb. this runs the turn signals. you hazards run on a seperate flasher and switch and will have nothing to do with your t signals
Same problem here when I first got my car. so +1 for the hidden relay behind the radio.
+2! the hazards and turn signals run on separate flashers. a lot of people say the turn signal flasher is behind the glove box. i think it depends on year maybe?? anyways, on my 91 GT, i found the flasher behind the radio (area). stock one is blue. i didnt have to remove anything to get to it. you can see it by laying on your back on the floor and looking up towards the back of the radio. it is press fit into a mounting plate, so it might take some effort to pop it out. hope this helps!
Check the turn signals flasher unit (located behind the center of the dash attached with a support bracket), I think you can switch the hazard lights flasher (located behind the fuse box) with it to verify it's not working.
i had the same problem when i replaced my heater core.
hope this helps.
also
The hazard swith is used as a bridge to provide voltage to the turn signals switch.
i found this out when i had my top switch,hazzard switch un connected when i put in my new speedo, without it pluged in it will not work.
place a jumper between the two wires at the hazard switch connector, these are white-red and orange-yellow in color and then check the turn signals.
