Airbag light on. NEED HELP!!
ThePope
25
Huntington, NY
I was cleaning my car today and after I finished vacuming it, I noticed the light is on. It isnt flashing or anything. Its just on. I tryed disconnecting the battery to see if it would go out and it didnt. I also hooked up my diablo tuner to see if I can retrieve any codes and that didnt work either. Can anyone tell me how to find out whats wrong it. If anyone can help I thank you.
Anthony :shrug:
You may have moved some wires around on the connections while vacuuming. The module is under the dash in front of the console. Check your connections. There are also some ground wires near it on the passenger side of the dash, in front of the console. They bolt to the dash, make sure you didn't bump and break those either.
I just recently converted my interior to all black. Int hat process, I changed out the dash. I made sure that everthing went back on the way I found it. But I also did check to see if I moved any wiring and I couldnt find anything. I was reading online and I saw something about the clock spring going bad in the sn95 mustangs. Is this a possiblilty?
I would take it to the Ford and have them look at it. Thats something I wouldn't want to play with. Not saying it will but if for some reason your airbag would go off your going to be spending some $$$ to replace it.
