another gt40p head question
shrbrt
the junkyard near me has a $49 all you carry on the american cars. well I struck gold. I got a set of gt40p heads and the upper and lower intake manifold off an awd explorer. all this for $51. (it cost 2 bucks to enter the yard). My question is, should I have anything done to them before installing? what about changing springs. I got a stock setup with an ecam and 70mm tb. I plan on keeping the 19lb injectors. would that be sufficient, or should I switch to 24's? the explorer came with 19's
For the GT40p's I believe you need different headers because of the angle of the spark plugs.
BUt as what you should do to the heads...I would bring them to a head shop and have them clean, magnaflux, resurface and regrind the valve seats, but thats me.
19 lb/hr injectors should be sufficient IMO
Agreed. I would also have the springs swapped out. I did mine myself and put the trickflow spring kit on them.
Have a machine shop check them over for you most reputable shops will go over them and install your springs and new seals for like $50.00. Crane makes a kit #44308 that has springs,retainers and locks that will give you a .550 lift tolerance they cost $120.00. You will also need to swap out your headers or get a set of shorty plugs and good wires with thermal boots. Your 19's will work!!
all you can carry?! :eek: they obviously didnt mean in one trip did they? or do you have like 8 arms?!?
VERY lucky find! one of the best ive heard! :nice: :nice:
19lbs are working for me right now, but like (above) said change those springs asap. I had a local engine shop look them over, check for cracks, clean them up, valve job, and put springs on for me.
I told them to find me a set of springs and i ended up with a set of Lunati springs for a decent deal (right around trick flow and everyone elses).
