my car is eating batteries...HELP
jmd2914
937
Napa, California
alright guys
i posted about a month ago about my battery/charging issues and it turned out to be my battery. have the same symptoms as last time. is there something in my charging system that would make my battery not charge correctly after only a month?? thanks guys
Joel
yeah i checked. i started my car about four times in a row after i figured out that it was starting to die again so i might have just killed it on my own but i dunno why it would start cranking slow again with the battery being new
that is a real problem, is it the stock alternator? is it putting out enough amps? do you have anything that would need the extra use of the battery, system, electric fan? etc....
Check the secondary power ground: it is between the back of the intake manifold and the driver's side firewall. It is often missing or loose. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges. Any car that has a 3G or high output current alternator needs a 4 gauge ground wire running from the block to the chassis ground where the battery pigtail ground connects. The 3G has a 130 amp capacity, so you wire the power side with 4 gauge wire. It stands to reason that the ground side handles just a much current, so it needs to be 4 gauge too.
The picture shows the common ground point for the battery & alternator
Picture courtesy timewarped1972
No secondary ground problems, look for a current drain: Small things like glove box or courtesy lights are often the culprits. If you have an aftermarket stereo or alarm system, it is also suspect.
The ideal method is to disconnect the negative terminal, and connect a Digital Multimeter (DVM) between the negative terminal on the battery and the negative cable. Set the DVM on a low current scale of 2-5 amps if it doesn't auto range. Watch the current draw, and then start pulling out fuses. When you see a sudden drop in the current, that circuit is the likely culprit. Note that the computer, radio & clock will draw less than 1/10 amp to keep the settings alive.
I ditto the second ground. also check your fender starter relay to make sure all the wires there are nice and tight. I forgot to tighten on after an alt install the other day and the engine didnt want to turn easily.
Check/clean every single ground wire you can find on the vehicle, from front to back, inside and out.
Also, if you have those silly lighted mirrors on your visors, either unplug them, or put a piece of folded paper or something between the flap and the button that shuts it off. I've found that the light sometimes won't shut off when you close the cover flap because the fabric makes it all loose and such (won't contact the button firmly enough to break the circuit), so you have to put a "shim" of something in there to make it shut off. Otherwise, you'll constantly be having a drain on the battery when the car's shut off, and that continual steady drain will eventually kill even a new battery.
