I've had the alarm on this car since I bought it from the previous owner, I'm pretty sure it's an older alarm unit. When I go to school, I disconnect the negative battery cable so that the alarm doesn't drain the battery. When I come back, I always reconnect the battery, which sets off the alarm. I turn off the alarm with the key fob and I'm good to go. The last time I was home (Thanksgiving), the key fob stopped working so I just locked/unlocked the car with the key. I picked up a new battery for it today but it still does not work and I can't drive the car because I can't get the alarm to stop. I've tried connecting it and putting the key in the ignition or starting the car, but the alarm won't turn off. There is a switch mounted in the console next to a unit that controls the sensitivity of the alarm, and I switched that to the opposite position it was in thinking it would turn it off. This didn't work either. I'm at a loss as to how to get around this thing
. i think it has almost 1km reception also, which is very nice. you can be inside a mall, or in underground parking etc, and it will still alert you if your alarm goes off.
) and connected the battery. Turning the key to the on and then off position and then flipping the switch might have worked? I pressed the button on the remote and the LED lit up. The doors lock/unlock with the remote now so everything seems to be working. Maybe there's steps to reset the remote after you install a battery I didn't know about... I'm off to Walmart to get some wire connectors to fix the horn connection and then after Christmas maybe I'll get this sucker replaced..
