Another Relocating Battery Help Thread
gcwh02
515
pottstown, PA
ok, ive searched this a few times but I gotta get this straight. I have 20 ft of 0/1 gauge wire-- I use this wire as a ground from the battery to the quad shock and also to run my + power wire from the battery to the solenoid. Do I also need a 2gauge wire to run from the negative terminal to my chassis ground up front near where there battery use to be? Am I suppose to run a 4 gauge off of that to the block?
dude mine is grounded to the body in the trunk, i dont think it matters as long as your engine grounds up front are good. ive never had problems with mine.
I used #1 for the power that goes up front to the solenoid. Also used a #1 for the ground that I ran all the way up front to the sway bar mount, from there I grounded the block also with #1. At first I had starting problems, but that turned out to be a weak battery. With my new battery it fires up everytime without any problems. By the way, its the taylor kit but I got some cable from a friends father that he got from work. Use can also use welding cable.
I used 1 gauge and ran everything back to factory locations. I'm also going to be changing the ground strap from the block to frame with heavier cable. I don't know if it will make a difference, but at least it will be a better ground. I also used an Optima battery. I didn't like the fact of having a hatch with a regular wet type battery.
For a battery cut off switch, see
http://www.moroso.com/catalog/categorydisplay.asp?catcode=42225 is the switch
http://www.moroso.com/catalog/images/74102_inst.pdf
Use the super duty switch and the following tech note to wire it and you
will be good to go.
Use the Moroso plan for the alternator wiring and you risk a fire.
The 10 gauge wire they recommend is even less adequate that
the stock Mustang wiring.
There is a solution, but it will require about 40' of 18 gauge green wire.
Wire the battery to the two 1/2" posts as shown in the diagram.
The alternator requires a different approach. On the small alternator plug
there is a green wire. On the diagram it is #904, lt green/red wire that connects
to the alternator and dash light. It is the sense lead that turns the regulator on
when the ignition switch is in the run position. Cut the green wire and solder the
40' of green wire between the two pieces. Use some heat shrink to cover the
splices. See http://fordfuelinjection.com/?p=7 for some excellent
help on soldering & using heat shrink tubing.
Run the green wire back to the Moroso switch and cut off the excess wire.
Try to run the green wire inside the car and protect it from getting cut or
chaffed. Crimp a 18 gauge ring terminal (red is 18 gauge color code for the crimp
on terminals) on each wire. Bolt one ring terminal to each of the 3/16" studs.
Do not add the jumper between the 1/2" stud and the 3/16" stud as shown it the
Moroso diagram.
How it works:
The green/red wire is the ignition on sense feed to the regulator. It supplies
power to the regulator when the ignition switch is in the run position. Turn
the Moroso switch to off, and the sense voltage goes away, the voltage
regulator shuts off and the alternator quits making power.
This setup uses a 125-150 amp fused power lead for a 3G Alternator.
For the stock alternator, you can omit the fuse & 4 gauge wire and use the stock power wire.
attachment.php
See the following website for some help from Tmoss (diagram designer) &
Stang&2Birds (website host) for help on 88-90 wiring and lots more…
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Diagram courtesy of Tmoss and Stang&2birds.
Rear mounted battery ground wiring. Follow this plan and you will have zero
ground problems.
One 1 gauge or 1/0 gauge wire from battery negative post to a clean shiny spot
on the chassis near the battery. Use a 5/16” bolt and bolt it down to make the
rear ground. Use a 1 gauge or 1/0 gauge wire from the rear ground bolt to a clean
shiny spot on the block.
One 4 gauge wire from the block where you connected the battery ground wire to
the chassis ground where the battery was mounted up front. Use a 5/16” bolt
and bolt down the 4 gauge engine to chassis ground, make sure that it the metal
around the bolt is clean & shiny. This is the alternator power ground.
The computer has a dedicated power ground wire with a cylindrical quick connect
(about 2 ½”long by 1” diameter. It comes out of the wiring harness near the
ignition coil & starter solenoid (or relay). Be sure to bolt it to the chassis ground
in the same place as you bolted the alternator power ground. This is an
absolute don’t overlook it item for EFI cars
Picture courtesy timewarped1972
attachment.php
Crimp or even better, solder the lugs on the all the wire. The local auto stereo
shop will have them if the auto parts store doesn't. Use some heat shrink tubing
to cover the lugs and make things look nice.
