I'd use the brown wire (parking lights - that's when the rest of your instrment lights come on). You can also tap into the dimmer circuit so your gauges are dimmed with the rheostat. Fuse 13 or the dimmer or any existing dimmer light can be tapped into.
I would tap into the ignition wire under the column that's hot during crank and running but most folks pick a switched 12 volt donor circuit and call it good.
Good luck.
