Set up/hp gains
I purchased a a 95 mustang 5 speed that has a E 303 and Edul. performer intake. I'm wondering what heads would be good for those two items. I'm getting a blower<vortech> for it, planning on running 10/12 psi.
The car has a 273 gear or whatever stock gear the stangs come with. I don't plan on reving the engine past 5500rpm because of the stock bottom end. How much power would this combo put out and what e/t am i looking at with a street tune?
I tryed "search" but its taking me way to long to find what i want. :shrug:
If you got the money AFR 165's if money is tight get a set of Thumpers or Ol' GT40 irons or Y's. The first thing you will want to do is lose that rear gear in favor of a set of 4.10's to get that thing up and rolling. I would not be afraid of revving past 5500 I would be more afraid of the 12 lbs. of boost you plan to put in it. We have a stock longblock 93 GT with a Vortech pushing 8 psi that runs bottom 12's. There is alot more parts you will need to run a blower with even 6 psi safely!
I like to think money is tight all the time. :) but if i was to buy heads why not 205 or is the 165afrs good for my intake? Is a 205 to much head for a 5.0 with stock bottom end? As for the gear i don't think i want to play with the car because i'm really not into the whole smoke show.
I'm personally never had a blower car so it would be my first time building one. I"m use to have a 4.6 cobra on spray reving damn near 7k. Very fun car but you can look up my name and see what i did to it, poor block.
But my goal for next winter would be a high reving built 306 with apr205 and intake/cam to match. I just don't want to buy things twice that is why i'm wondering maybe just get the 205s. This is all assuming i don't like the blower set up.
The higher you get up the totom pole in parts the more bottom end you sop from it that is why a steeper gear is needed. I personally would not put 205's on a street driven 408 let alone a stock 302 shortblock. If you wanted see if you can get someone to swap your E cam for a F cam. (.512 lift, chargers love em) Then get a set of TFS heads and a 3.73 gear. With a supercharger set for 8 psi or so there is no reason bottom 12's shouldn't come with ease.
Well wit that low gear + blower<assuming i get one that boost right away> wouldn't be fine? I can understand if i get a blower that starts boosting at 2300-3200 how a really low gear can hurt. As for the F cam how much hp do i gain in the power band. I know the F cam is amazing for blower/turbo cars just not **** if i wanna spend a day putting it in. :shrug:
Nice to know i don't need 205. I was thinking that is to much head for a 5.0. :rolleyes:
With that h/c/i combo all you are doing is making more power in the same 302 cube engine that was designed to operate from idle to the factory set 6250 rev limit. So with the introduction of higher rpm potential and more room for cfm's of air you shift your power band up higher which will now make power from say 2500 to 7000. One way to get bottom end back is more cubes to get more torque into the equation the other is more gear/ convertor to get the engine to its sweet spot sooner taking away that initial dead spot in the bottom end. A 3.73 gear will not hurt you it will just get you to the good stuff sooner. I would say the F cam would give you a good 10 horse over the E just because of its design it was ground for that application. I cant see any reason why an engine equipped like stated with 8 psi wouldn't make 400 horsepower and run high 11's with a stick.
In this case, because you do not want to rev past 5,500 RPM, AFR 165s would be hard to beat, IF you got the money.
I do not believe that AFR 185 heads are too big. The camshaft just needs to be set-up for it.
Small heads = Large duration
Large heads = Small duration
I would not run 4.10:1 gears or steeper with the power you are planning on pulling, unless you got some fairly serious suspension/tire work.
Lol o man i can just see myself spending 10g easy on this. But the car is going to get a 10 way adjustable shocks/struts w/coil overs from Strange. I can't see myself trucking USA.
So what do you guys think i should pick up first the apr 185s or a blower.....DON"T SAY BOTH!!!??? lol
That carcraft article is nothing new.
That is on an engine dyno. So take 15-18% for drivetrain loss, then take another 15% for accessory loss, and what do you have?
The same old numbers anyone else would get, if not worse:)
The lower your gears the less your tires will spin. :nice:
I know that sounds odd but that's just the way it works :D
You'll be much happier and it will be much easier on other parts with the lower gears. :flag:
:flag: Yea that is how i feel. When i was 18 i loved showing people my stang can smoke the tires. As i got older it changed. It changed to wanting to dead hook and fly pass people.
As for being easier on parts maybe but i know the rear end,trans/cluths won't like that hooking from a low gear. Spinning hooking spinning hooking isnt as bad as a dead hook on stock drive train. :nonono:
:nice:
I swapped a set of 3.90 gears & an Auburn Posi in place of the stock 2.73's & open diff in my Monte Carlo last summer... needless to say, it was well worth the $800 i spent.
i would get the gears swapped before anything, then go with either the AFR 185 or trick flow has a new fully ported head that they sell and i think its also avalable with a 185 intake runner, they are really nice, i'd take them over afr's anyday
Im thinking of going trick flow. I have a machine ship here in chicago that will port a heads on a CNC machine for 250 a head. Is that a good price for CNC porting?
I talked to more and more people and like everyone else here is telling me to get a new gear. I'm the type that likes to see for myself but this time i'm just going to do a gear. I'm a big fan of 373 but i'll be happy with a 355 since it will be a blower car.
