Vacuum lines on intake
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
How can I remove the vacuum tubes on the bottom of an upper intake without damaging them? I'm getting ready to paint my Explorer upper/lower, and I want to remove the tubes both because it would be easier to paint and also, I don't need all the extra vacuum lines for my old 5.0. Somebody told me they are press-fit in. Is this true? I've been too afraid to tug on them to find out.
On my explorer intake the black one with the three connections on it was a press and fit and I could actually pull that out, I wouldnt try to pull the others. The two long ones in the back I cut to size, then I had it powdercoated.
For the vac connections on the explorer intake I put the egr/thermactor line on the extra port on the vacuum tree, on my '91 there a extra port anyway. I put the rest in their logical places, and capped a few in the front.
Well I'm going to try to pull at least the ones I don't need and fill the holes with JB weld and sand them down real nice like before I paint. I guess we'll see how easy those are to pull, and go from there. If anybody else has some real experience with this, your input is still welcome.
Did you damage the 3-way connector when you pulled it out?
No I didn't damage it at all, I was just messing with it and I noticed that I could wiggle it. Took it out with pliers checked for gunk and pressed it back in.
I wish I would've got rid of that vac connection right over the left valve cover.
Be sure to grind off that nasty bracket thing on the front of the intake.
Check it out: I got all the lines out , no damage. Gonna clean out the holes, throw some loc-tite in there, push 'em back in and call it a day. After I paint the intake, of course. Which has proven to be a problem... Sooo many little holes to tape off...... And the old paint is sooooooooo hard to strip (I've bought more hazardous chemicals in a week than a meth addict does in a year). But if all this hard work and loss of brain cells pays off, its gonna be a pretty sweet looking intake. Expect pics for sure. :flag:
