Obviously there is a wide variety of opinions when it comes to tuning the eec-iv.
Please don't take the following as a personal attack... I'm just throwing out my opinion for discussion...
Easier solution.
Get a better meter from Pro M or pmas.
Using a C&L and a tuning device on a fox is a contradiction. A mediocre at best meter and an expensive tuner, just doesnt' make sense.
There is error introduced in 2 ways by calibrated MAF meters.
The first way is the obvious method by which the meter is calibrated. Since a C&L meter is not 'calibrated' as a system, there will obviously be a certain degree of error potential. This is due to the fact that a factory sensor is placed in a C&L housing and that system is 'calibrated' using a sample tube.
In this regard ProM would most likely be better, and according to the error numbers commonly cited, ProM is much better.
However, there is also a certain amount of error introduced by simply using a scaled meter in an ecu that was originally programmed for a 55mm MAF and 19Lb injectors.
The larger the aftermarket injector/MAF used, the larger that error would be.
It doesn't matter if the meter is from C&L or ProM...
Couple this error with the error created with an aftermarket cam...
Pretty soon error starts stacking up...
Guys run NA 11's with stock shortblock 302's without a grand in tuning equipment, they have been doing it for years.
Tuning devices have made no improvements on those times.
I've watched these cars tuned in person. If the car is assembled correctly and the timing and FP are set correctly, chips and programmers pick up less than 5 hp. They can improve driveability on wild setups, but if there is a driveability problem with an E cam and gt40ps, the problem is somewhere else, not the computer.
Instead of tuning equipment, spend the money on a better meter, and a custom cam, i'd bet that picks up way more hp than any tuner does.
You are completely focused on hp and track times.
I don't have an issue with this, but some of us want to drive our junk to work without issue...
I would like to see an example of a car that was professionally tuned, and didn't drop et or make more hp on a dyno...
If you do have an example you can bring to the table,
then my next question is going to be EXACTLY what tune parameters were modified????
I am very curious where you came up with the 'less than 5hp' number?
Again,
Just throwing out my opinion to fuel the discussion
shrbrt -
I get the impression that you aren't JUST looking for max hp or the lowest et... (I could be wrong though???)
Seems like you are also looking for an opportunity to learn more about the ecu, and how it opperates.
If my impression is correct, then you would probably fair pretty well with a tweecer rt/moates or PMS setup.
If I am way off base and you just want the stupid car to run right, then an SCT tune (performed by a professional) may be a better choice.
either way, good luck,
jason
