To anyone I suggested using an RTV coated bolt in the dipstick hole..............
D.Hearne
11,730
south louisiana
:D That **** don't work when you don't run a PCV system.:rlaugh: :stupid: Did this on the 331 in my 77 Comet. Been battling an oil leak at front and rear of the pan. Changed the Felpro 1 pc gasket yesterday to the early pan 1 pc gasket. Got it all buttoned back up, let the extra RTV I put on the pan radius's cure overnight. Refilled the crankcase this afternoon, started engine. Watched for more leaks. No leaks........good. Time for test drive..................:hide: Get down the road about 5 miles from the house, let her rip coming out of a curve. Smelled oil burnin'...........Looked in the mirror..................Looked like the Space Shuttle took off, horizontally.:flame: Oil pressure's OK:nice: , turn around, drive back to the house, up on the ramps. Get under the car, oil's dripping like rain under the car:shrug: It's coming from the now open hole where I put that RTV coated bolt...........but the bolt's gone..................:rlaugh: :stupid: Did something similar but used glue coated bolt instead. Also rigged a PCV system to keep the pressure from doing that again................... No leaks now.:nice:
LOL, well sometimes the best is learn from our mistakes. I just put RTV and nothing more over the hole, so I hope that will be enough. I will be running a PCV system though.
*cough* In our helicopter maintenance pubs, RTV wil sometimes be called for...but never where a petrolem product is involved, then we use a similar, stickier, smellier substance we call 8802. Reason: petroleum breaks down RTV.
Better solution - tap the dipstick hole using a 1/8NPT tap. The hole is a little oversize, but pipe thread tapers, so it will take a thread. Dab on a little Loctite, and thread in the brass or steel 1/8NPT plug of your choice. You'll never have to worry about it again.
Another solution is to do what Ford did and put a cup plug in the hole if it is not going to be used for the dip stick. They sell them at NAPA for about $1 under Clevite P/N 219-2185
Tim
Dumb 'ol me is still trying to understand why you would build an engine without a PCV system. I'm old enough to remember the debate over the 1st PCV systems and how the hot-rod crowd claimed it would cost hp. When they dynoed engines without and then with PCV the PCV engine always made more power. And used less oil. And since you were not trying to vent the crank case through a vent tube your oil stayed cleaner.
I didn't have a PCV originally with the 83-85 Stang valve covers, the baffles didn't survive the roller rocker clearancing, hence running a PCV valve with no baffle is a sure fire way to foul the spark plugs and drink quarts of oil in the process. I've since swapped covers to Moroso tall chrome steel (plain ones---no logo on these :nice: ) that have baffles. With the Stang covers, I had one open breather cap, the other had a 1/2 nipple that I routed a hose to the aircleaner, kinda hoped that would have been sufficient to vent the crank case. DIdn't happen though, I guess the 331's got a bit too much blow by at WOT for that to handle.I really wanted to keep the Stang covers as they pretty much matched the 3x2 air cleaner top. Maybe some day I'll get some baffles rigged in em.:shrug:
No experience with those, but on the 65 I run Erson full roller, aluminum rockers and I put dye on them and rotated the engine with the covers hand tight. I then heated and ball-peaned the baffle to clear the rocker. I've actually won $150.00 over the years because some genius at a cruise-in will tell me I'm lying when I tell them I have full roller rockers. You should see the look on their faces when I pop the Cobra covers and ther are those nice aluminum rockers.
