Rear Coilover Stiffness Question
Ok i just got done installing my Strange 10way adjustables with QA1 150# springs. After i was finished installing the new upper shock cross member and and lower mounts i set the car on the ground. Its feel like its riding on solid blocks, the rear is so freakin stiff.... Is that how its suppose to be, i know for sure its not bound on anything and the shocks are not bottomed out. And the shock is set at the softest settings. Any ideas?
-AJ
I jumped on the hatch area and it didnt even bounce/budge and im not a little guy either.... Seems like for drag racing you would want the back soft so its can transfer the weight to the back tires. These 150# springs were the ones that Wolfe Race Craft recommended me to do when i bought all this stuff.
-AJ
yeah, for drag you usually want softer rears i think. you positive you didn't maybe adjust the wrong way and go all the way stiff??
Yeah I'm sure, but i didn't think about how much i compressed the springs before i put the weight of the car on them... Maybe the springs are at their limit? Any rule of thumb that i should go by on how much to tension the springs?
-AJ
I run 250# springs on the rear in my coupe with the MM coil overs at all corners and I think 325 on the front. I'm thinking of going with maybe 450-500 on the front, because the front end seems like it's on the soft side for what I want, but definately way stiffer than stock or most lowering springs.
I got my problem fixed now.... Thanks
Hey did you ever run your car at the track with better tires, I'm heading to the track tomorrow and wanted sometime of setup caparison to go off of.
-AJ
-AJ
What was the problem?
I did run it at the track, but never got a good clean run in. On my best run I still missed 4th, and the density altitude was around 6000'. I ran a 12.3@112 though.
Hoping to get some clean runs in this season.
I had the suspension set to low and i didn't even notice that the post on the lifts were sitting on the subframe connectors.... Its all fixed now and got my strange 10 way adjustable set where i wanna start tweaking on them at the track.
-AJ
