suki243
Thanks D.Hearne, I'm just a young gullible mind; teacher said that and i was like oh. I may have not used the exact terms but that was the gist.
GM is also coming out with a very cool engine that uses electromagnets, in addition to the rotary engine concept, it looks very cool and very promising. Along with a system that uses generators that engage when you push the brake pedal, the rotation of the rotor then powers the generator thus charging your battery just a bit, when one releases the brake the generator lifts off the rotor.
The two products are not the same thing. Veg oil diesel production is nowhere near as energy consumptive as corn based ethanol is. Ethanol isn't made from fermenting oil anyway. There's several products taken from oil seed. These are the hulls, meal, oil and starch (in corn) Ethanol is made from the starch & sugars. The only process I've seen to make bio diesel is to simply remove the soap stock, that's a simple process of mixing a chemical with the oil, the soap stock rises to the surface. There's also a lot more BTU content in the finished product, unlike ethanol. And using the oil for fuel, doesn't cut into the food prodution, the oil is simply a by-product. If anything ethanol production should be banned from using corn, there's too many other sources of fodder for this to need corn. Using the oil for fuel, is just anther added market for the oil, which is already been produced for decades.
He's probably still trying to think of a better arguement to come back with as far as the "pro" side of this idea.
