OK, so I swapped my engine from a manual '91 to an automatic '90 and then swapped to manual on the '90. Should I be experiencing any computer problems as a result? I'm doing some troubleshooting on this thing.
I actually got to the point that I brought the car to my mechanic and he had questions for me, specifically about the computer. Apparently, they can't connect to it to run codes.
For some reason I couldn't get our 6000 dollar Snap-On scanner to pull the codes on my car, but I can manually pull them with the LED technique. See if you can pull your own codes. But to answer your question you shouldn't have a problem swapping the ecu.
