Vibration problem
LaserSVT
3,548
233
So im getting this annoying vibration through the whole car after 115 mph. It dosent shake the steering wheel and I can tell its eaither the drive shaft or the rear end. The rear does not make any noise at all normally but at that speed I cant tell. So before I throw parts at it has anyone ever gotten a high speed vibration from gears before? Or is it more than likely the drive shaft and I should just man up and get a FRPP aluminum one?
I have the same problem. It's only in 5th gear correct? When I'm hitting 115-120 in 5th it feels like the car is going to shake apart. Then once you hit about 130-135 it goes away and is smooth. I do believe it is a drive shaft related issue because of gears. From the information I've seen, FRPP alum drive shaft should correct your problem.
