Last night I decided to try and fix my dip stick oil leak. I noticed on both heads that oil was between the block and the head. Got me nervous. I started looking around and noticed two oil puddles on both side off the timing cover. Im thinking its the intake manifold leaking out of the corners. What do you think. Pics below.
Also what does antifreeze look like in the oil. Does it look like a milky cloud in the oil or should you be able to see it pool together. I noticed that my oil was a little milky with a white haze to it.
I figure if the intake gasket is leaking then the water might be getting in to the oil through the lifter galley.
Oh well, still put down 265 horse and 300 pounds of torque on the stock cam with no tune. Not bad I suppose.
