i think im going to change my trans fluid tomorrow or friday. question is the fluid, will i be ok if i pick up some Mobile 1 ATF from vatozone? or should i grab a different brand or type?
another thing: I went to my local auto parts store and they only had 4 synthetic Mobil 1 ATF's - not too many people buy it bulk. I believe Walmart has quite a bit tho.
well i was trying to find a good trans fluid and mobile 1 came highly recommended to me by a friend. i checked out the website and it passes all of fords and gm's "standards"
i really just want to stop the rock crushing / tumbling marbles sound in my trans when it is put into 5th gear.
If you hacve the TR3650 trans only put 3.2 quarts in it. The trans will be a little noisy but 3.2 is the correct level. If you put all 4 quarts in it it's possible that it can get tougher to shift.
are there any special tools i need to change the trans fluid, how do you pour the new fluid in? the filler hole is kind of tight to get to. so im assuming that i will needs some sort of toll to get that done
