Hesitating/Surging and Popping under Load
i have a 1988 LX 5.0 SD
Mods:
A/C Smog Delete
timing 13*
Mac LTs
Mac o.r Prochamber
Flowmaster
3.73s
okay under load and this is about 90% of hte time the car surges and or hesitates, like fuel is being completely cut off to the engine and it starts to make a popping noise
it is intermittent, for example leaving work today it ran like a gem while ****ing aorund with my buddies vette, but i got home parked it couple hours later took it back out and it ran like crap about, surging and popping noises and what ever else... its under and kind of load it happens but under WOT it will not happen as long but under partial load somtimes it just keeps going so i have to let off and push the clutch in....
say im rolling in first gear... at 2500 rpms the car will start bucking like fuel is just being cut off
the Pump is new
the Cap Rotor Plugs are new
this started happening shortly after my Exhuast was put in. i did run the car for a week with out O2s just had hte holes plugged because i was waiting for the extensions in the mail... and it just got worse and worse till where it is now that i just know when i hit the throttle and let the clutch out the car is just gonna pull the same old BS.
I also had a similar problem under part throttle and it turned out to be the HEGO ground. It's an orange wire that extends from the engine harness to the back of the engine. Somehow it had broken and caused all kinds of grief.
this is a problem with the way the ecm gets data to decide how much fuel the car needs. Reason I say this is because you say its fine when its at wot, which means the computer is going off of known good values rather than trying to calculate from sensors and what not.
I would check the following:
1. Maf - get some electronics safe carb cleaner
2. tps
3. iac
4. as always check all your grounds
are you throwing a check engine light? If so you can check the code with the self test plug under the hood and count the times the cel blinks.
similar
My 87 SD does a similar thing. I am dumping a truckload of parts into it currently so I'm hoping to have the issue solved, but I won't know for a few weeks and it's back together.
Mine would only happen at WOT under load. It would pop through the intake and fall on it's face and hesitate. Happened more when it was cold, after it was warmed up it rarely happened.
I replaced a cracked vacuum hose and it got better but still did it. The car always smelled like it was running rich and the EGR and air intake passages were absolutely caked with carbon as was the old exhaust I took off when I got it to put on my Magnaflow stuff.
I have (8) 19lb injectors that have been sonically cleaned with flows sheets. My guess is I had a leaky injector, but we will see. The originals were really grimey looking. The upper and lower intakes are now spotless and ported so that should help too. I have a new FMS 65mm TB and spacer and it has a new TPS on it so that could be a fix too.
I have a code reader with a digital readout and there are no codes. :rolleyes:
Shutgun approach? :D
IAC
Just make sure you pick a screwdriver with a head that matches the screw heads the closest. I used a large screwdriver with a shallow head and they came out pretty easy. You don't want any wiggle room between the screwdriver head and the slots on the screw heads.
Okay im still having this problem haha
So far i've done
Cap
Rotor
Fuel Filter
Fuel Pump
ACT sensor
MAP sensor (not a typo the MAP or BAP I AM SPEED DENSITY!)
Timing down to 13*
Cleaned IAC
EGR Delete
New upper intake Gasket (somone said somthing like the intake gasket could be leaking and letting in air that hte computer is not seeing.)
Wires
Checked TPS .74v at idle couldn't get a reading under throttle cuz i did it solo and i had to hold the lead tips on the pins
Checked the HEGO ground to the back of the block
Waiting on Doing the Fuel Pressure Regulator, just need a guage to adjust it.
Gonna get a New ECT sensor also.
(and can any one tell me where the coolant temp sender is? my guage in my car does not work)
So far i've done
Cap
Rotor
Fuel Filter
Fuel Pump
ACT sensor
Timing down to 13*
Cleaned IAC
EGR Delete
Wires
What about the oxygen sensors? My car was acting the same way when I realized the wiring was fraying and coming loose out of the actual sensor part. I'm sure they were old and needed replaced anyway but two new o2s fixed the problem.
