crushed cyl #8 sparkplug
gabe3586
40
Well it all started when I was trying to fix my idleing issues today. I was about a block away from my house and decided to look at a few things under the hood. I pulled vacuum line off of the EGR valve and noticed that it would only start sucking when givin throttle so I switched it with a line that was sucking in air all the time. Well it seemed to idle alittle bit better so I start driving it and hear the dreaded knocking noise from my motor, I quikly pull over and switch the vacuum lines back how they were, but its still knocking. I limp it home and shut it down, well 5 minutes later I start it up to see if I can pinpoint where the knocking is coming from, but it was'nt knocking after I started it. I ran a compression check and when I got to Cylinder #8 I found a crushed spark plug, changed that and it runs fine now. Im assuming it didnt hurt any valves seeing as the compression on all 8 cylinders matched. My question is that, what caused this? Im assuming if it was a streched piston or something it would keep knocking. Did messing with the EGR valve somehow throw my timing/or computer way off?
My first question is;
Are you positive you gapped each plug and checked it again before installing it?
IMO, and it doesn't mean much when I don't know what you have in "it"... but there's no explanation for your plug to have have a bent ground electrode while installed in your running engine. My first guess would be that you dropped/pushed it into the plug boss, it smacked the side of the plug hole and bent the electrode.
My next question;
Did you replace your plugs with a different tip? Example; did you go from a standard tip to an extended tip or possibly a 3/4" threaded boss plug?
Yes im possotive they were all gapped correctly. Im running the standard autolite plugs gapped at .052. The specs on the engine are gt40p heads, e303 cam, gt40 intake, probe pistons, and eagle rods.
egr doesn't necessarily get constant vacuum. if that was the case, it would be hooked straight up to the intake vacuum and not the egr solonoid.
my guess is that you have the wrong plugs. which plugs are you running?
