ROLLER OR NON ROLLER?
roller allows you to run a steeper/bigger cam profile, the roller can roll up a steeper incline and drop off quicker than a flat tappet, if you tried to do some of the things with a flat tappet than you do with a roller you'd wipe out the cam.. remember the flat tappet is 2 flat surfaces sliding on each other and the roller is rolling over the hills, eliminating cam wear and freeing up HP due to less friction.. IMO it's not worth it to convert for a street/strip car, but if you can find a roller block for the same price as a flat tappet go for the roller. Cams and lifters are also much more expensive for the roller, but the lifters can be reused on any cam, it's not matched to that lobe like a flat tappet
Just adding to the first posters answer....the roller valve train is where it's at. Cuts way down on the friction allowing the engine to rev up much more smoothly and freely than a non roller cam would. The roller cam will also outlast the rest of the engine, where a non roller engine will experience considerably more wear on its lifter faces and cam lobes throughout its lifetime.
As far as EFI vs. Carb goes. At this point (or at any point IMO) you're better off sticking with the EFI set up. You'll make as much, if not more power with it along with better off idle torque and drivability, as well as increased fuel economy and cleaner emissions levels. If you were starting from scratch with a stripped bare chassis, then going with a carbureted set up might be more financially viable to you, but at this point It would be more expensive for you to work backwards removing the EFI equipment and prepping your vehicle for a carb swap, than it would to forge ahead with the EFI parts.
as far as EFI or carbed goes i figured that. I'm looking at as much if not more to switch to carb. Emisions isnt a concern. I figure i could have about &1200 alone to go to carbed, to where i'd have $400-650 to stay EFI. I come up with these prices cause all i really need is intake and flywheel and balancer.Maybe a touch more for EFI? The intake is probably gonna be $675 shipped unless i can get a trick flow R for cheap or pick up another brand cheap? I wont use BBK or professional products or the typhon crap. peace
john:p
stay EFI using the blue injectors with a stock mass air will let you run E85 or pure alcohol with an adjustable fuel pressure regulator. alcohol give you many tuning options.
we dont have E85 here the lowest oct is 87 and the highest is92. Blue top's? those are 24's so how will the stock mass air work with them? peace
john:p
