Just adding to the first posters answer....the roller valve train is where it's at. Cuts way down on the friction allowing the engine to rev up much more smoothly and freely than a non roller cam would. The roller cam will also outlast the rest of the engine, where a non roller engine will experience considerably more wear on its lifter faces and cam lobes throughout its lifetime.
As far as EFI vs. Carb goes. At this point (or at any point IMO) you're better off sticking with the EFI set up. You'll make as much, if not more power with it along with better off idle torque and drivability, as well as increased fuel economy and cleaner emissions levels. If you were starting from scratch with a stripped bare chassis, then going with a carbureted set up might be more financially viable to you, but at this point It would be more expensive for you to work backwards removing the EFI equipment and prepping your vehicle for a carb swap, than it would to forge ahead with the EFI parts.
