looking for a new cam
wildstang90
87
Bristol, TN
Been looking at the B303 cam. looks like with this cam I dont have to worry about the piston to valve clearance with still good low end torque and peek power some where around 4500. So far not a lot of mods on the car as of yet but will be putting a new set of heads on in the nere future. One more thing is there anyhting I should change out at the same time as the cam to save time or just replace somehting thats worn. The car have 170k stuill runs strong so any idea and all the help I can get is welcome.
Until you're ready to do the heads, cam and intake I wouldn't bother. The B cam may be advertised as having good low end torque but I wonder what they compared it to. Mine has ZERO torque below 1500 RPM. The stock cam is a much better match for the stock intake and heads.
I 100% agree with maryland. That cam is no good.
Just a little clarification. The cam isn't well suited for stock heads and intake. I do run the cam and I'm 100% satisfied with it's performance. I knew it was low end challenged before I put it in so there were no surprises. There may be better cams out there for my application that meet all of my criteria but someone would have to prove it to me before I'd switch.
i had gt40 p's and an explorer intake.
Thanks for the input .. Cam will just go on the waiting list. I should had added to that this is not a daily driver its just a toy that will see alot more track time than road.
If you plan on track time get serious with your setup from the start.
They say go big or go home.
306
f-cam
afr 165's
sheetmetal intake
full mac exhaust
75 tb
75 ma
30lb inj
3.73 ,5spd . 4.10 auto gears
and some n2o
thats a good setup imo
Thats where I am headed I have 373s in now everything on the inside has been removed other then the driver seat. Started the removal of the smog crap and the AC unit. I hav been looking at the Jegs intake dont rember the name but its just a box no runners. I have been looking at head and a cam but right now I dont have the cash its 1 thing at a time.
replace the timing chain when you decided to do this. You have to be right there anyway so put a new one in just in case your old one is stretched. Also a good time to do a basic tune up on the car if it needs it.
