Does anyone know how to set the mach 460 stereo to automatically turn the volume up with increasing car speed? I had to replace my battery and now the stereo defaulted back to normal and I forgot how I did it originally.
It's not done only by the radio programming. You'll need to take the radio out and follow this DIY:
SSV LINK
Is this only for 2001 models? In my 2002 the SSV works and as far as I know it doesn't have this mod.![]()
If your car is already equiped with "Speed Volume", you can access it by pressing and holding the power button on your radio while the power is on. One the speed volume menu appears, you can select values 0-7 of how much you want the system to scale the system's volume based on the vehicle's speed. 0 is no scaling, and 7 is maximum. I usually don't go higher than 1 in my hardtop, and 2 in my convertible. Hope this helps.
I did not know that!If it worked for you before you disconnected the battery, then most likely you don't have to do the mod. If your car is already equiped with "Speed Volume", you can access it by pressing and holding the power button on your radio while the power is on. One the speed volume menu appears, you can select values 0-7 of how much you want the system to scale the system's volume based on the vehicle's speed. 0 is no scaling, and 7 is maximum. I usually don't go higher than 1 in my hardtop, and 2 in my convertible. Hope this helps.
