Name these stroker parts
So I found out it is a 50oz., its stamped on the snout of the crank like Rick said,
I am ordering some parts right now to put the shortblock back together....I'm ordering all new bearings, rings, gaskets and headstuds and whatever else.
What bearings should I get? Clevite77 came out of them
The mains say
R Clevite 77
5.05
MB2121P
.010
Lower
and the rods say
C Clevite 77
5.05
CB634P
.010
They don't have oil grooves in the top or bottom, I would like to get ones with grooves on at least one half, it would seem to have better longevity? there's so many differet series, metal, sizes I'm not sure which is best....
It's going to be a street car and plan on shifting in the 6k area, and boost it in the future.
Rick....or someone that has experience help a man out :SNSign:
Based on the P series bearing I assume it is a cast crank...
Clevite 509P -010 for the mains (your journals have been turned .010")
Clevite 634P-010 for the rods (your journals have been turned .010")
There is not P-series or soft babit bearing that has an oil groove for the 302 main that I am aware of, ACL may have something or Calico. You may want to contact Calico they sell some nice coated bearings for a little extra insurance although the Clevites will be fine.
Get a nice plasma moly top and a low tension oil ring to free up a little power... If boost is int he future you may want to go with a standard tension oil ring.
Rick thanks,
about the P-series, the internals are forged(im pretty sure anyway)....I'll have pics of my buildup attached so you can see for yourself. So IF it's forged these would be the wrong bearings in the first place?
I would just think an oil groove would be better but I guess as long as the oil's pressurized and the crank is turning there won't be any "dry" spots on the bearings, you're the engine builder here so I'll take your word for it since I've only built/machined a couple engines so far.
I'm a little mixed up on how you explained my old main bearings, the rods have 634 and so does your example but my mains have 2121 on them and you put 509 for the mains?
Also I was planning on getting the rings that are listed here, the regular replacement I guess you could say (file fit .030) Part number 315-0049-035
from this website http://www.probeindustries.com/Pistons/Piston Specifications/PistonSpecs.htm
I'm definitly going to boost it in the futue so I'll make sure it's the non low tension rings. Do you know the number I would need for the right rings I need? :flag:
Here are some pics
ok so if I put it all together right now with the heads when they're done (65cc) and with a .040 gasket (assuming its a .010 still) deckheight I should have around 9.8 compression ratio, since I really want to boost it in the future I want to get it down to like 9 to1 at least, sound good? I don't want to get a HUGE gasket and kill the quench area
So should I just get new pistons? I can get one set that will bring it down to about 8.8 or so, but would that make it a dog while it's n/a?
one more question do ALL 331's have a 3.25 stroke? I'm not sure what kit this is and I don't have the fancy journal tool to measure it so I want to make sure it is in fact a 3.25 so I can order the right pistons and gaskets....?
Any advice?
