good deal or bad? (heads)
fastfords4
Don't know to much about heads but these are on the local forum....im looking to do a simple H/C/I, sooner or later and wanted to see if i should snag these up....(was thinking a cobra intake and a frpp E- or B- cam.......would these heads compliment this setup or are they to big?)
Brand New Eddy victor Jr. cnc ported heads w/trick flow dual valve springs installed.
300cfm @ .600"
2.05" intake
1.6" exhaust
70cc chamber
Harland sharp rockers 1.6, hardend push rods
$1100
if you get the heads dont use a cobra intake, the heads can support alot more power than the cobra intake can. you could probably make a few more HP with a custom cam or newer OTS cam. the FMS cams are good but are older designs and there are better cams out now.
cenok: yes i did....are they to big? that was one of my questions....
foxfan: what intake would you suggest i you think that the cobras 350hp rating would be insufficient?
an eddy vic jr manifold would match it perfectly.
the cobra would work but why limit yourself, the cobra intake WILL choke those heads. those heads will support alot of power, more than 350hp... the cobra and vic jr heads just arent matched parts.
and like jason was saying, those heads are pretty big for a 302, you will need to turn some rpm to use them to their full advantage, their are better suited for a stroker or 351
