Body cracking issues..."Fox"
Well after I put a wider tire on and a new clutch the rear fender flare cracked. The car is supercharged w/ a 355 gear,Lts, full exhaust and anderson power pipe. I was running 12psi but kept lifting the head due to using stock head bolts. I am slipping the belt and running 6psi and its cool. Running 6psi lets me floor it all the time.
I'm new to the 5.0 fox hype and was wondering if there is a company out there that makes fender flares for the Fox? Whoever owned the car before me just bondoed it. I did a hole shot yesterday and hooked hard so i'm guessing that is what did it.
I do like the car and would like to restore it, keep it clean. Any other info on the body that I should watch out for that you guys could think of? Fox bodies are a dieing breed these days at least in Chicago.<Salt=Rusty fox>
Here are some pics:
Yes looks like tire is hitting it. I would be looking at a different off set rim. Get those tires tucked in a bit. How wide are the tires and what offset rims? The other option is to airbag the passenger side spring. That will stop the passenger side from squatting so much.
........... The wheels are 17x9 with 275x40 zr 17s. They don't stick out past the flare its almost even with the flare just alittle in.
