Added in some numbering so it would be easier to read...What are you willing to put on the table to make that gaurantee.
1. Have you done any strength testing?
- YES, i've installed hose clamps on a compressed spring and they hold
2. Hell, have you done any strength calculations?
-Don't need to, i know it works
3. If someones vehicle is damaged because they tried your method, would you cover the cost of the damage?
-How would the vehicle get damaged? Even if the spring were to come unsprung is would be traped in by the strut, spindle, control arm. It count not go anywhere. Explain the damage
4. Unless you are willing to take responsibility for your claims, you shouldn't be making them.
You don't have to take responsibility for claims, and if you did. Your saying that you'll take responsibility if the "correct method" spring compressor brakes and kills somebody?
1. Strength Testing requires the part/specimen to be loaded to failure. This is done in a test lab, and massive amounts of data are usually taken.
There is NO WAY you can say hose clamps are reliable and safe at spring loads, UNLESS you know the Plastic limit and Failure Load.
(this is the kind of stuff I do for a living btw
2. This is exactly the kind of ignorant back woods comment I get so frustrated with. Again,
If you don't DIE in the first round of Russian Roullette, Does that prove the game is safe?
3. Once again you prove that you are ignorant, and that you don't even care enough to think things through...
Joel posted a link to a spring that went uncontrolled. Imagine that spring shooting around inside your wheel well.
If you don't see how that could cause damage, then you are a retard after all.
4. What claim have I made?
To answer this question properly, you will have to quote me... you don't get to 'rephrase' my words on this...
Your claim was pretty straight forward...
Sadly though, you have nothing to back up your claim of safety...Joel posted a link to a spring that went uncontrolled. Imagine that spring shooting around inside your wheel well.
Use the Hose clamp method. It works perfect. Its safe as well.
jason
