Not only did I get a 20 HP increase but even though the car was really dirty
it washed it self and rotated its own tires when I wasnt looking......
Weight reduction every time you change your oil too, as you're flushing out what's left of those those pesky rod bearingsI only run 1.5 quarts of oil...saves money, time and weight
Firstly: if you run two identical runs back to back on the same dyno a difference of 4-8rwhp is not uncommon just for dynoing a car.
Second: Changing the oil after 3-4k miles is going to net power whatever oil you chose. Show me a car with 6 new quarts of Mobil 1 synthetic 10w-30 on a dyno for 5 runs, average it, then empty the oil and do the same with a "better" oil with the 5-average. Let me see a difference of 6-9rwhp+ and i'll put some weight in the results if the temp and humity remained the same. Otherwise these results are rather useless.
Remember synthetic doesn't mean instant power results, it means durability over a period of use and resistance to characteristic change under high temperatures due to the lack of impunities and stability of laboratory made components.
It was more directed at hsk, royal purple fans, and all the others who think there's a special formula oil that's going to make them power somehow; if there was, everyone would be making the same stuff.He was joking![]()
