Pcv valve and breathers
MY 85 GT
1,852
208
104
New Jersey
Ok i just removed my PCV and im running 2 breathers in my valve covers...The cheapo pcv valves from autozone are crap i just ordered 2 motorcraft ones form ford...Actually i dont think running 2 breathers are going to hurt anything will it? The car seems to idle way better and seems to run better also...
As long as you run only a closed PCV system or you run only breathers (don't mix the two), you should be fine.
Thanks I run 2 moroso 3 inch open type breathers on both valve covers...I want to get 2 K@N type down the road so i should be ok that way?
That's fine. Just delete the PCV altogether (dont forget to deal with the bypass hose from the inlet to the oil filler).
One small point: PCV is more effective because you use manifold vac to actively pull vapor out of the crankcase. Breathers simply let pressure ooze out.
Is this a EFI thing only? My 82 Capri with carb has a PCV in the breather and a breather on the other valve cover. Should I close off theother breather?
Good question.
It's actually a mass-air thing. Mixing breathers and a PCV valve leads to unmetered air concerns.
One EFI its either a closed PCV or breathers, I prefer the closed PCV since a passive breather system is not very good at removing the corrosive vapors from the crankcase.
On carbed cars its a breather with PCV set up. So I guess its an open PCV system.
Personally I like to run a PCV system vs a passive system with the breathers.
