Pretty sure I'm misfiring
Well I un-plugged every COP individually to try and figure out which one was the problem. They all seemed to make the car run worse when unplugged (Except one which wasnt as bad as the other 7) which makes me thing that maybe its not a misfire.
I got new plugs anyways Motorcraft SP-493. Should I stay with those or get copper ones?
Plugs are done. Im going to take it for a spin after I get finished with this.
I went with the platinum Motorcrafts.
Platinum is good for dd without poweradder.
Pulling the COP won't do anything unless the car is misfiring at that exact moment while your under the hood. The way i've had to find bad COP's in the past is go and drive it with my foot in it untill it throws a code. Then use predator to scan and find out which cylinder. Then you can check the plug, or swap plug to another cylinder, see if the mis moves or stays. I know it very crude but you gotta do what you gotta do when your trying to get your car together for a race.
Its still misfiring. So that leads me to believe that maybe a COP is bad.
Ill pull them off again tomorrow while the engine is running and try to figure out which one is bad.
I think it only does it when the engine is under load.
I wish it would throw a code so I know which one it is. :mad:
Or find the cylinder, swap the injector to another, then swap the COP to a different cylinder, if the mis moves to that cylinder you found your problem.
Def sounds like a COP though, they go bad alot on these cars.
So go out at a low speed, put in 5th and romp it, stay in it even though you'll cring, after about 10 sec a code should pop up.
I didnt see your post before mine so thats why I suggested unpluging the COPs again.
I'll do what your suggesting to get a code tomorrow and hopefully ill be able to get it fixed.
My step dad has his 03 grand marquis that he never drives in the garage. Theres my new COP :rlaugh: just kidding
When im in 4th or 5th and crusing if I go WOT theres a terrible shudder. The shifter looks like its going crazy..:rlaugh:
Hoping that its only a bad plug. Im pretty sure they're the original ones so they're due for replacing.
Just happen to me too. Shifter shakes like crazy on 5th gear , that means missfireing . I had 2 go out since I got accel coil on plugs. Thank god that I bought from brother performance cause then exchange fist one like month ago and I just send one yesterday to have it exchange . In 4 months 2 went bad so I will warn others not to get accel coil on plugs.
I got the problem fixed. I managed to have it set the ses light off. Turns out cyl 7 was misfiring. Went to my buddies house cause he had a few extra COPs and replaced #7 and all is well. :D
I was actually thinking about getting a set later down the road, so thanks for that.
The main complaint on stock COPs that I've heard of is either the spring in there gets broken or the boot cracks and leaks the spark. There is a kit for like 100 bux that has a heavy duty spring and boot combo that is suppose to take care of this problem and keep the spark nice and strong all the way to the plug. I don't think its a "performance" part but it is suppose to keep the COPs working at 100%. I don't know if I could find the link for that anymore but I'll check when I get home from work.
That would be great if you could find it.
One of the boots has a slit in it.
