9 94greenmile New Member Nov 2, 2003 19 0 0 Ms. Sep 7, 2007 #1 Sep 7, 2007 #1 I replaced bank 2 o2 sensor and disconnected battery, cleaned MAF, and still the lean code exists. If I turn the car off when it comes on it does not return. any ideas. thanks
cjones Founding Member Jul 20, 2002 1,561 0 37 Avondale, AZ Sep 8, 2007 #2 Sep 8, 2007 #2 you changed the driver's side(back 2), right?? check for exhaust leaks and vacuum leaks.
O oneofakindfxbdy New Member Sep 22, 2008 21 0 0 Sep 22, 2008 #3 Sep 22, 2008 #3 the car should have around 20 lbs of vac... i would check that first cause i have a similar problem on my cobra and im missing vac
94GTCoupe 10 Year Member May 7, 2006 1,412 92 79 CA Sep 22, 2008 #4 Sep 22, 2008 #4 check those 3 vacuum hardlines on the passanger side.fix any cracks/leaks you find.
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Sep 23, 2008 #5 Sep 23, 2008 #5 oneofakindfxbdy said: the car should have around 20 lbs of vac... i would check that first cause i have a similar problem on my cobra and im missing vac Click to expand... 20 lbs is a lot. 20" hg is more common.
desertcox05 New Member Oct 3, 2007 379 0 0 south atlanta Sep 23, 2008 #6 Sep 23, 2008 #6 clean the maf. that will sometimes through a lean code
